- Joined
- Nov 29, 2009
- Messages
- 10,258
A few years back, I had a shop work on my boat and they put sealed bearings inside pds housing. Basically the drive shaft that connects the outdrive and engine together. I was peeved because it's supposed to have two 6206 open bearings if I remember right. The guy said I could still grease it and it would still squeeze it's way past the seal. I have my doubts. I don't understand why they didn't just remove the seal on one side if they couldn't find open bearings, or whatever the reason was. So, with that being said, can you still force grease into a sealed bearing?
