Have any of you driving older vehicles ever replaced your spare tire?
Does it influence your decision if it’s a full-size or compact?
Does being stored away from the sun make you trust a spare tire for longer than one that’s been on the road the same number of years?
Last year in spring I inflated the original donut in the 2004 Corolla to 55 psi in the interest of preparedness. In summer it came apart layer by layer... sitting in the trunk.Yes. I am more concerned with a 60PSI spare tire being in a hot car then the age.
So why didn't you get a proper, full size spare?I ordered a new space-saver tire the next day and had it installed within the week. Once again, we use this van for traveling all over, so having a spare we can trust is important.
My car a full size spare doesn’t fit and the space saver rubber doesn’t appear to be manufactured.Have any of you driving older vehicles ever replaced your spare tire? Does it influence your decision if it’s a full-size or compact?
The depth of the spare compartment under the van is sized for the space-saver only. Otherwise, I would have gone to a junkyard and picked up a used full-size rim and then had a new tire mounted. One of our cars is also this way - not enough depth for a full-size spare - space-saver only.So why didn't you get a proper, full size spare?
My Maxima is like that, sadly.The depth of the spare compartment under the van is sized for the space-saver only. Otherwise, I would have gone to a junkyard and picked up a used full-size rim and then had a new tire mounted. One of our cars is also this way - not enough depth for a full-size spare - space-saver only.
So, effectively, you don’t have a spare. A 23 year old tire may, or may not, hold air when you put a load on it.Tundra is a 2001. So is the spare.
