Originally Posted by mbacfp
Are the cold properties of an oil reduced throughout an OCI? For example, 0w-20, if one is at 80% through an OCI does the 0w part degrade or become less effective in cold situations? Or is it's cold properties primarily due to base oil quality?
In service, oils are allowed to slip a W-rating. Shannow has covered this rather extensively in the past.
PPD's work by reducing the temperature at which wax crystals form in the base oil. This is a characteristic of Group III, II and I; any base oil that has wax in it. Low-viscosity FT GTL base oils are better in this regard, having lower pour points than other Group III base oils.
PAO has no wax in it, which is why PAO bases have insanely low pour points.
An oil with a wax-containing base will hit a wall: its crystallization point where the viscosity drops off a cliff as the wax crystals form. This is one of the reasons that Pour Point is no longer used to determine cold temperature performance, because it was found that certain cooling/warming cycles changed significantly the temperature at which this occurred. The resulting product would be unpumpable at a temperature it was classified to pump at.
This is however why oils with significant slugs of PAO have very low pour points. A PAO-based lubricant can still fail CCS and MRV (generally CCS) for a given W-rating while still pouring at a much lower temperature. This is because PAO's performance is quite linear at these low temperatures; it doesn't have the viscosity "cliff" characteristic of a waxy base oil.
As Bryanccfshr noted, base oils oxidize, which causes them to thicken. PPD's and VII's both degrade in service and as such, the W rating will be impacted. A 0w-xx is allowed to become a 5w-xx and a 5w-xx is allowed to become a 10w-xx...etc. Whether this will actually happen or not of course depends on the type of service and the base oil combination used. A lubricant that's heavily PAO based would be, IMHO, far less likely to slip a grade than one that's Group III. PAO is more resistive to oxidation and it isn't depending on those PPD's to keep it fluid at low temperatures.
