Whether or not iron is trapped by the magnet, the cumulative iron that I show is what was shown to be in the oil by the UOA so it is tangible and valid. Now, to your point, it means there is more iron in the oil than the test shows NOT less and some of the particles trapped by the magnet can be too large for the UOA to detect.Interesting data. You presented the concept of “ cumulative iron”, which is not really true because the magnet inside most diffs takes much of that out of solution. That’s what the “mung” is on the magnet. Case in point, do a test on a fluid that was in the diff for 100,000 miles. That’s why many manufacturers call it a lifetime fluid. I change at 50,000 miles, but most vehicles will make it to the wreckers with the original fill. The owners manual for a 2022 Ram 1500 calls for changes at 30,000 miles. I see you are doing changes at 5,000 miles. Wow.![]()
You drained and disposed of the fluid, correct. Then you added fresh fluid, ran it for 5,000 miles, then drained and tested it, correct? If so the cumulative iron is a hypothetical number. The interesting question would be, what would happen if you went 100,000 miles and then drained and tested the fluid. I would bet it wouldn’t be that same as your cumulative iron number, because the magnet would take a lot of the iron out of solution. That’s the only point I’m trying to make.Whether or not iron is trapped by the magnet, the cumulative iron that I show is what was shown to be in the oil by the UOA so it is tangible and valid. Now, to your point, it means there is more iron in the oil than the test shows NOT less and some of the particles trapped by the magnet can be too large for the UOA to detect.
Correct, however, your scenario exists in the tests that I have done at this point in time. The magnet is already capturing metal and I have cleaned it every time that I have drained the oil. The magnet would not be cleaned until 100K in your scenario and the magnet would become less effective as the metal builds up--e.g. the magnet will be "full" at some point and the motion of the oil would put some of the metal back into suspension and repeat again.You drained and disposed of the fluid, correct. Then you added fresh fluid, ran it for 5,000 miles, then drained and tested it, correct? If so the cumulative iron is a hypothetical number. The interesting question would be, what would happen if you went 100,000 miles and then drained and tested the fluid. I would bet it wouldn’t be that same as your cumulative iron number, because the magnet would take a lot of the iron out of solution. That’s the only point I’m trying to make.![]()
^^^ Is that 500k intended for class 8 trucks with large capacities ? ^^^When I serviced the 70HD diff and bearings I realized that it have never been changed by a PO - 65k miles, 51 years.
I had to dig out 1.5" of sludge from the pumpkin with a stir stick and then flush.
Dana has new lubes that are covered by warrantee, "save 1.9% fuel", and up to 500k intervals
https://spicerparts.com/parts/lubricants/commercial/fuel-efficient-synthetic-gear-lubricants
I have pretty much done the same thing on the cheap - Valvoline Dino - white bowl - sunlightYou drained and disposed of the fluid, correct. Then you added fresh fluid, ran it for 5,000 miles, then drained and tested it, correct? If so the cumulative iron is a hypothetical number. The interesting question would be, what would happen if you went 100,000 miles and then drained and tested the fluid. I would bet it wouldn’t be that same as your cumulative iron number, because the magnet would take a lot of the iron out of solution. That’s the only point I’m trying to make.![]()
The Dana 44 Advantek axles shed more iron than any I have owned or worked with. With that said, I saw a substantial reduction by REM Isotropic polishing the gears when I re-geared. They are starting to trend like "normal" axles do.The Rubicon pumpkins shed like a golden retrieverNothing like my GM/AAM axles …
Bet that smelled yummy, hate how old diff fluid smells.When I serviced the 70HD diff and bearings I realized that it have never been changed by a PO - 65k miles, 51 years.
Don't they all stink? Sulfur-based additives I find stink when new.Bet that smelled yummy, hate how old diff fluid smells.
Funny story, I made my oldest son change the diff fluid on my old Dakota, it was about 6 yrs old and roughly 50k miles on it. So he pulls the cover and it comes out, gets all over his hands, and then the smell hits him and he starts dry heaving. Hahaha I laughed and laughed - he goes that's not funny dad.. yes it is.
They do not all stink. Ours smells closer to a motor oil than a gear oil. It has worked quite well in the 43 car.Don't they all stink? Sulfur-based additives I find stink when new.
Junior does need to learn the hard way, best way.
