How often do you change rear diff fluid
Every 50,000 miles on my 3/4 ton Burb with a 14 bolt. I used to tow a 7,000 lb trailer 5 times a year for 10 years. Used 75w90 AC Delco or Motomaster fluid. Always synthetic. I have 225,000 miles on the diff. The fluid always came out black as midnight.
Last diff oil I changed was on my F150 at 100k miles and was 31 years old.. It's still noise free, works good and did not self destruct.
I'd have to look back at my records. I think I did the Ranger at 1000, and then again at 10,000. Probably won't touch it again until 30k, maybe every 30k after that, especially if we ever go RV'ing.
4runner changed the diff fluid at 70k, next probably at 130k.
Ford E150 4.6 changed the factory fluid at 200k, not thinking about changing it again.
I change mine in the ‘02 Jaguar XKR every 30,000 miles. It always comes out looking like the La Brea Tar Pits and smelling like a decomposing Saber Tooth Tiger.
I use the Mobil 1 75w-140. More costly than the 75w-90, but performs better under harsh conditions. I use the same fluid in the ‘66 Shelby Mustang GT350.
Z
PS the Jag manual also makes one of those “sealed for life” statements for the rear ended lube. And the Jaguar manual said the same thing regarding the A/T, but revised the specification to every 60,000 miles later when they pulled their head outta the sand.
Sealed for life ? Don’t ever believe it.
Most axles generate the vast majority of wear metals at 15K or less and from that point despite longer and longer OCIs, the wear metal generation reduces exponentially. My Ford axles have stood up to that synopsis very well, but the same cannot be said for the Dana Advantek axles under my Jeep as noted in the comparisons shown below.
With that said, I say it depends on operating conditions, axle design, oil capacity, oil type, and other factors. For your 2006 RAM, I seem to recall AAM (the manufacturer of that axle) having a rash of issues and Dodge reduced the OCI to help compensate for it.
In the end, you can hardly go wrong by changing the oil early or on a regular basis. Of course, there is cost involved and there are also some OEMs who state "lifetime fill" with zero definition as to what that may be, but on a piece of equipment that does not have a pressurized or filtered oiling system, I prefer to err on the side of prudence.
I do every 15-20k on my 2012 Ram. I tow my 11k TT with it all over the place during the summer. A few quarts of 75w90 are cheap compared to a diff. I use Mystic from F&F at about ~$7/quart.
FWIW the service interval on the Ram is 15k for severe duty.
Just my $0.02
About 1,000 miles when new then at 40 to 50,000 miles, after that 50,000 miles or more depending in what kind of service the vehicle sees.
60-75k (unless called for sooner) wherever the Trans interval happens to fall within that range. I always knock trans, t-cases, and diffs out at the same time.
I've noticed with several vehicles, doing the first drain at 50,000 kms, the fluid is grey. However, the next 50,000 kms it comes out fairly clean. So IMO, after the initial wear metals are out, a 80-100,000 km drain interval should be fine.
Interesting data. You presented the concept of “ cumulative iron”, which is not really true because the magnet inside most diffs takes much of that out of solution. That’s what the “mung” is on the magnet. Case in point, do a test on a fluid that was in the diff for 100,000 miles. That’s why many manufacturers call it a lifetime fluid. I change at 50,000 miles, but most vehicles will make it to the wreckers with the original fill. The owners manual for a 2022 Ram 1500 calls for changes at 30,000 miles. I see you are doing changes at 5,000 miles. Wow. :oops:
'18 Stinger GT2 (LSD) specifies every 36k, so that's happening next weekend. Using Red Line 75w90.
