So I stopped at a garage sale and the truck (95 f150) would not restart, just a click from the solenoid. So I put the parking brake on, stuck the shifter in neutral, wedged down the clutch and duct taped the ignition to the crank position. Now the output terminal of the solenoid showed 12+ volts, so I went under the truck to see if the hot connection to the starter showed 12 volts. I am looking up at the starter noticing the hot wire is on top and figuring how to reach it and suddenly the truck starts. Well that is fine, it's what I wanted, but now the engine is driving the starter way faster than it was meant to go, so I whip around and start tearing off duct tape. Apparently no harm, but in the future if I am going to do this test, I will be better off to pull the center distributor wire out first. As it turned out the connection for the wire off the solenoid to the battery was very corroded and not all that tight, cleaned it up and it's starting fine.
