Originally Posted By: Gebo
One of my engines holds 6 qts. Another holds 3.5 qts. Am I overthinking or should I change the smaller capacity engine oil more often?
I think they should all be the same regardless of capacity, unless you install a larger or smaller oil pan then what came with the vehicle. A smaller engine has less surface area to wear, so it needs less oil. A larger engine has more wear area, so it needs a larger capacity. smaller engines also produce less acid than larger engines because they burn less fuel. That is if the engine is functioning properly. The engineers have already figured everything out for you.
