I understand that the majority of engine wear takes place immediately after cold start-up before the oil circulates under pressure to the engine. But after that, before the oil reaches normal operating temperature, how much wear happens then? My pappy always told me to warm it up and drive it easy till warmed up...
During the 10 miles or so, plus or minus it takes to warm the engine oil up to temp, it's a lot thicker and therefore doesn't circulate as rapidly. Thick oil in the bearings doesn't necessarily sound like a bad thing from a wear protection standpoint.
So should I run it easy or just drive normally? Is it a problem to run it hard during this warm-up period?
