- Joined
- Jun 2, 2003
- Messages
- 23,591
This is about my bicycle, but since it's more about gears and grease than about bicyles, I'm posting here.
I'm wondering how much grease should remain between gear teeth and on the contact areas of these shaft drive bevel gears:
(no grease)
The grease that was originally on those gears was a dark grey and rather sticky ("thready" between fingers) grease. Ironically, the recommended grease was "non-sticky" wheel bearing grease. Go figure.
I replaced the grease with AMSOIL 2000 Racing Grease #2&2EP GC LB. With the AMSOIL grease the gears run with less resistance, but I'm worried that there is not enough lubricant on the gears.
It appears that almost all grease gets squeezed out between the teeth and collects around the outer edge of the gears. Where the teeth mesh and contact (concave side of hub gear -- not really visible in the above picture!), I do not see any grease.
Can I assume that a sufficient amount of oil from the grease is present on the contact areas, or should there any grease be "stuck"? Would a lack of lubrication result in abnormal noise or be noticeable somehow before abnormal wear occurs?
![- -](http://i4.photobucket.com/albums/y108/moribundman/gears.jpg)
(no grease)
![- -](http://i4.photobucket.com/albums/y108/moribundman/gear_lube.jpg)
