Originally Posted By: KW
I can't do a thing with the EFI on my cars. How would you adjust it by using a chip? Other than that I think you're SOL.
On the other hand I can tune a QuadraJet with a wide band O2 meter, metering rods and jets. AFB's and Holley type carbs are easier to work with. Idle and off idle adjustments can be made with the off idle screws, air bleeds, etc... With a long duration high over lap cam sometimes the throttle blades have to be drilled to get it to idle on the idle circut and not the main circut.
With EFI and a big cam say 240ish or more @.050 you are stuck with a poor running car that burns your eyes, stalls and just over all runs bad. Unless you have a really nice high dollar aftermarket EFI that is tunable. But those don't come on regular cars like a Jeep or a Ford van from the factory.
Factory EFI is good for cold startup only.
The TwEECer, AFM PMS, and SCT devices all have the capability of adjusting things on EEC-IV Ford ECM's, with SCT making stuff for newer vehicles as well.
My Camshaft Innovations custom cam is ~230/240 (at .050), and ~.550/.550 (exact specs not given) and I expect it to run just fine with the chip that will be burnt for it.
My Town Car (laugh away) is cammed as well; runs a stock Mustang A9P ECM with a C&L MAF and idles just fine (albeit with a very sassy lope) and passes E-test with a pair of Magnaflow high-flow cats on it.
I know of SEVERAL Mustang guys with nothing more than an SCT chip to optimize the A/F curves and to provide the ECM with the new MAF transfer curve and updated injector size that pass E-test with flying colours and start and run like stock.
EFI (at least the Ford stuff) is VERY tunable and flexible in terms of performance mods. Don't knock it until you try it
