How Much Auto-Rx Do I Need To Buy?
Jacksonville Beach Fl
How much Auto-Rx do I need to buy?
If you have never cleaned your lubrication systems before, it will take 2 bottles for a passenger car under 100,000 miles. It will take a full bottle to run the cleaning phase in the motor. It will take ½ bottle to treat the automatic transmission. It will normally take 1 to 2 fluid ounces to clean up a power steering unit. This will leave you two to three maintenance dose applications after the initial cleaning of the motor. See the application instructions for greater detail.
If your passenger car or light truck has over 100,000 miles, or has become sludged, it is recommended that you buy 3 bottles. It is recommended that you run two motor cleaning applications. The third bottle should be used for the transmission, power steering and maintenance doses.
In both cases above you have enough product to achieve the maximum desired results in most cases.
Take advantage of the quantity discounts available on the order page.
