Originally Posted By: Bill in Utah
Originally Posted By: RamFan
For those of you who do not extend due to warranty. Do you plan on extending once the warranty has expired?
Depends on the vehicle. Verified by UOAs I've increased my Corolla from factory OCI of 5k to around 7-8k on Conventional.
Truck is OLM. Sticking with it or 6 months. (Its more time than miles) Contour is 6 months. New vehicle once its out of warranty will stick with OEM recommend.
Bill
Not bad with the Corolla. With my 07 Civic EX i've extended from the factory 6-7k to around 10-12k but that's with a synthetic. (not sure if the OEM Honda brand oil is a semi-synth or not) I'm sure i can go longer and will experiment doing so with the upcoming OCIs.
I honestly don't see what the big deal is with warranty. Doing extended OCIs, backed by UOA with a new-ish vehicle will not cause it to automatically VOID the warranty.
I've had my 98 Camry and both my 07 Civics in for warranty work and not once was i asked when the last time i changed my oil or what brand it was.
EVEN if for some unknown reason you do go in for engine related warranty work, its usually a recall on some part and your lube of choice doesn't matter in that case.
With a good quality oil, seeing as they keep engines spotless, even with extended OCIs, will the manufacturer really know that here you are going 3-4k over the factory spec'd OCI??? I doubt it.
If i could go back 4 years ago when my Civic EX had JUST finished breaking in with around 25k or so, i would have started doing 10k OCIs with synthetic oil and just call it a day in regards to engine lube, all while saving some coin on maintenance and being ECO friendly at the same time.
