Originally Posted By: grampi
How do you figure? Before the engine starts to warm up, it, along with the coolant, is the same temp as the ambient air temp...even when the engine's running...
This is getting nuts. Defroster on full blast even with cold air
AND THE WINDOW CRACKED OPEN A BIT HELPS air flow. And that air flow will HELP get the frost/fog off the windows.. obviously it wont melt ice. When the air starts to warm some cars warm up very very quickly and i dont know how they do, others take awhile, then the air gets warm and the ice outside can melt through HEATED air blown on same windshield. And yes, i know that running defroster is supposed to "take away from the heat available" but when the engine is under load, it warms up faster (unless you cant see when you start the car, which may require wiping) BUT 1. Airflow,
from the window a crack open and the defrost running at ANY temperature, IT USUALLY PROGRESSES FROM COOL TO HOT AS PER PHYSICS combined with 2. Window a crack open GREAT help from equalizing ambient humidity INSIDE car to outside, which is why fog is there in the first place.. plus rear defroster on, etc.. will get you going.
Flick the wipers, too..
Also please recall that "having the window open will also help the AC flow and assist on a HOT day." Same reason.. vacuum/airflow. Then you close the window and saved ~3x the work of if you were to try to force it out on Recirculate, or the setting that appears colder, never could figure that out.
