On cooling systems with unpressurized expansion tanks (i.e. radiator has a pressure cap, but the expansion tank is effectively open to the atmosphere) how long should one expect it to take for the coolant level in the expansion tank to stabilize (assuming the temperature is about the same every time the level is checked)? In my experience the level always drops for a little while after draining and refilling as air bleeds out of whatever crevices it's stuck in.
Watching the coolant level in our truck since I just did a drain/refill along with another job, and I just thought I'd see what kind of anecdotes are out there so I know if/when I need to start looking for a leak.
