10 mins for my Mazda, 15 mins for Camry Vee6, <20mins for Honda Civic.
Next time just go over in your neighbors yard, dig a small hole first and drive over the hole with your vehicle. Now the oil has some place to go and not run all over. Viola.. oil changed!quote:
Originally posted by den_s:
20 min old oil drain
5 min filter change
15 min clean mess
2 min recycle used oil in my neighbor driveway (just kidding)
One of the advantages of changing your own is that you can make this job easy for next time. I've found that if you put a small amount of silicone grease on the gasket of a spin on filter it will come off much easier next time. Oil works too, but not quite as well. Leaving the filter on a long time can also make it difficult.quote:
Originally posted by Hermann:
Just did my '05 Accord 4 cyl for the first time.. What a PITA.. The ?????? $$$$$$$ at Fearstone had the filter so tight I almost had a stroke getting it off..
