Dart board ...Say what, how did you ever come to that conclusion?
Mobil 1 seem like stick to the engine part the longest
Dart board ...![]()
that was a flukeI like intelligent molecules and currently using it in one of my older cars. this car has a $4/qt budget for oil. I may reduce the budget for this car to ST or Kirkland levels but Castrol GTX Magnatec Full Synthetic 10W30 has a 6.1 Noack that not many can beat or match. Not even fancy oils.
This is of course the only answer you could give.No!
I heard from one of the school principals that some of M1 molecules were classmates with the Magnatec intelligent molecules.
You know if you hangout with bunch of turkeys , you can't soar with eagles kind of thing.
that was a fluke
Dart board good. Pros use roulette wheel!Dart board ...![]()
My PC cost is minimal, and a tax write-off.Plus your PC cost.
Incorrect, so many 10w30 engine oils have a lower Noack . In fact that may be on the higher side for 10w30.I like intelligent molecules and currently using it in one of my older cars. this car has a $4/qt budget for oil. I may reduce the budget for this car to ST or Kirkland levels but Castrol GTX Magnatec Full Synthetic 10W30 has a 6.1 Noack that not many can beat or match. Not even fancy oils.
Oils of yesteryear were thicker, which helps them stick to engine parts longer before drooling off due to gravity.
C’mon man. Marketing sells lots of products. If Castrol uses that line and is successful oh well.Regarding the discussion of Magnatec here, I do wonder if Castrol can be sued or at least taken to task for the use of the term intelligent molecules. It is marketing. I, for one, would or could be taken by it.. however, are they not just standard molecules, same base oil and slightly less stuff than Castrol Edge?
I recall hearing that any oil will cling to internal engine parts, probably more so with an ester base oil, as was mentioned, something to do with that base being more attracted to metal, I am not 100% on the science, however @High Performance Lubricants also mentioned use of a tackifier in the additive pack, if they wanted to add or if that also comes into play here.
dont forget the moly crap too.....I like intelligent molecules and currently using it in one of my older cars. this car has a $4/qt budget for oil. I may reduce the budget for this car to ST or Kirkland levels but Castrol GTX Magnatec Full Synthetic 10W30 has a 6.1 Noack that not many can beat or match. Not even fancy oils.
I'm turning into an old man and want to be more pedantic lol. I agree with your statement.C’mon man. Marketing sells lots of products. If Castrol uses that line and is successful oh well.
All else equal, higher viscosity means high film strength which means it sticks to parts longer. With oil, the term "light weight" refers to low viscosity, not low mass.Curious, how do you figure? Wouldn't a lighter oil be more defiant of gravity longer than a heavier oil? Assuming no other factors, such as rain washing it off.
I opened up my motorcycle engine after sitting for 1 year, the cams still had a light film of oil on them.Does anyone have any idea how long a protective layer of oil stays on the engine parts after shutdown? I am not talking about enough oil for a lubed start. I am just talking about a thin film that would prevent rust from starting. This is on a car that is not driven much. I drive it ocassionaly to keep the battery charged and burn off any water that may have condensed in the oil. I am now wondering at what point does the engine become totally dry and rust can set in. I would think it would be in the order of days or weeks because whenever there is oil where I don't want it never makes sense to think the part will just drip dry and be oil free, ever. With the engine being hot on shut down I can see it keeping the oil that remains hot and much more likely to just run off so I don't know.
That's impressive. On the opposite end of the spectrum, Lycoming O-320 and O-360 engines are horizontally opposed pushrod engines having the cam above the crankshaft. Because the cam sits up high, after residual oil drips off it is exposed and can corrode. Cam lobe corrosion/decay/pitting/spalling is common for these engines if they sit unused for more than a week or two on a regular basis over time. And this is using relatively thick oils: straight weight 40, 50 or 20w50. Owners (like me) frequently use the Camguard additive in these engines.I opened up my motorcycle engine after sitting for 1 year, the cams still had a light film of oil on them.
10w-30 oil.
