How long do Rhino Ramps last?
I was wondering how long these non-steel ramps can last? I've got a set that are over 10 years old and seem fine. I usually put some weight in front of them to help keep them from sliding when driving up on them.
I've had mine for over 2 years and they still work great. I often use them for full-size trucks and other heavy stuff and not even on a flat surface!
My ramps are 10 yrs old also and just used them, no problems, still have the rubber pads so no sliding.
Mine had the rubber pads too at one point. I believe they kept falling out and disappeared at some point. I've been putting 25 pound weights in front of each and that seems to minimize the sliding.
Great question … but not sure you will get a quantitative answer … something like exposed to heat, ozone, cyclic stress reversals being plastic … Ok, and that means ?
Personally I'd retire them at 10 years … it can be life or death when they collapse
Signed, Pine-O-Ramp user …
There are a lot of variables, mine have always been stored in a garage (non heated though).
Heaviest I've used is a 4,800 pound minivan, my truck is a two wheel drive short bed standard cab and I think it weighs less than the minivan. I don't think I'm coming close to exceeding any weight limits, it is the front end after all not the whole vehicle.
I'm sure Flo Tools would put an "expiration" date on them if they were concerned - the same way car-seat manufacturers do. They claim it's from plastic degradation, sunlight exposure, etc.
Originally Posted by Eddie
Mine are 14 years old
Ok … so that means 99% of the members (minus me) should use cheap plastic ramps for at least this long …
PS… OP asked for a reason
Mine are going on 2 years. I personally would replace them when they started cracking or some other indicator. Probably should put a couple jack stands under them for good measure, even though im guilty of forgetting often.
Mine are about 8 years old now, they still look fine. Is there any labeling/stamping or expiration date by the company indicating if/when they should be replaced? It might pay to call and ask the mfg. to find out for sure.
Yes … put something there … saw a guy in his driveway with a tire/rim underneath the side he/drain was on …
Cracked ribs beats dead …
Anytime I used anything to jack my car up I get in it and jiggle around before climbing under it. You can get some cheap jack stands if you are concerned.
Remember to chuck those rear tires with something good. Test your chucks.
Great question
My neighbor borrowed a set of mine and left them out all winter. Like in the snow etc
along side his house. They are two years old but I'm afraid they are toast.
Right on... Heck even a oak tree stump that is large in diameter would be great too. ..
