How is the PurePower! test going?
This is from a company that is discussing a similar subject and you can call them to get the proof that oils will flow was below 12 microns
Question 11:
Won't 0.1 micron filtration remove the additives from my oil?
Answer:
No. This is a myth that has been disproved by a leading oil company. The additives in the oil are in solution and cannot be removed with the Filtroil system. For results on these test results please call us at 1-800-638-3866.
