How is the 5.0L Coyote in F-150?
can you reference a tsb for 2015 coyote and oil consumption?? I believe you are conflating some years of coyote engines with the plasma coated cylinders of more recent iterations.
It was for 2018-2020. It was a PCM re-flash that left the throttle open a little on deceleration to prevent high vacuum and a different dip stick with a 2 qt add to full window instead of the standard 1 qt.
https://static.nhtsa.gov/odi/tsbs/2019/MC-10169811-0001.pdf
The current gen coyote has a wet belt oil pump drive system like the 2.7 TT and 1.0.
I Do Cars has torn down the 1.0 and 2.7TT. Both wet belts looked absolutely terrible. This reason alone I would avoid the coyote, or the 2.7 at all costs.
What’s the difference between the Coyote in Mustang and F150 ?
Ive heard the tune and intake manifold for more low end torque…
I know on the Mustang the tick is nothing to worry about and my wife’s 2020 consumes very little oil. I installed JLT catch can and it does catch a nice amount of oil when I check it every 5K miles.
  • Like
Reactions: wtd
Thank you. @Bill7 wrote is as all-inclusive of the Coyote. As mentioned by another poster my understanding was the consumption issues presented with the change to plasma cylinder lining.
I hate the internet. the 2.7 has been one of the most reliable powertrains that ford has ever produced. you dont even hear anything bad on the forums and thats saying something. because anyone who ever has issue comes to the forums for answers. there were other comments equating gen 3 with gen 2. and others that have complained about parts between the aluminum and steel trucks that were changed or said that were changed and the part number stayed the same. people just talk and have absolutely no idea what they are talking about. when looking at a used vehicle please do your diligence and find something clean and have it checked out by a mechanic. beyond that any used vehicle can have problems and its a risk that you have to be willing to take. look up front end issues on youtube and see how many tundra videos come up or how many injection pump issues they've had or how many have transfer case issues. just whatever you do don't listen to random people on the internet, take the vehicle to reputable mechanic have them give you a rundown of the vehicle.
b_b, I'm sure there are hundreds of thousands of 2.7L's that will be ok, but there will be secondhand owners who are shocked when their belts tear, and I stand by my original comment. Ford makes terrible engineering decisions, that belt looks terrible in the video. Maybe when the engine became cooked due to lack of lubrication it caused that belt to deteriorate quickly, but I highly doubt it. Same with his 1.0 video with oil starvation and the belt looked like a dinosaur chomped on it. My takeaway if I was a 5.0L, 2.7L, or 1.0 owner would be to shorten OCIs and plan for replacing the belt.
the 2.7 has been out for eight years. i have never seen a post about the oil pump belt. never. i also stand by my original comment. there will always be outliers and horror stories, no matter the make or model.
I think I only the later ones have an oil pump drive belt
My belt concern is with engine or oil solvent type additives such as B12. Getting that stuff in the oil seems like that’s a good way to damage a belt
The fact that I know the belt is there, is enough to give me heartburn. Even if it's reliable to 300K I still don't like it.
As an update, another one of our 2018's is potentially down for the count. Maybe 120,000km on the clock that has the usual wiring issues and stalling. No discernable chain slap but stalling with a over rich code (can't remember which one though). It cleared itself once in a while but always came back. I figured the map/maf might be dirty as it swills oil like I drank beer in my army days. The dealer just came back saying it needs a new engine. Regardless of what the second opinion says, I've never run a truck that embodies so many problems.
I will chime in and allow my blood pressure to spike for a bit. I think the 5.0 F150s are an absurdly large POS. Ford did a tremendous job of engineering such a pile of garbage.
Now the caveat, I have several hundred thousand km on various versions from the 2013 to some new 2021 or 2022. my office runs four F150s at a time and our neighboring offices have similar.
I prefer the 2014 I had run up to a few years back. Handled rough roads better than the new "aluminum" bodied ones. Worst issues were the vacuum hubs leaking and grinding. I don't think we had any vvt issues or engines grenading.
Now the 2015s and up had hub issues and everyone had vvt solenoid issues. Had many trips to the dealer and indy shop. All had to have the top ends opened up. The 2018 I just retired had its engine opened twice for solenoids. They stall and drink oil worse than a coked up Toyota. Oh and then endless timing chain slap and then every F150 has a poor rear wiring harness. All of them. Any gravel road use ends up with the usual, license plate lights get knocked out, then back up camera, then electric e brake, then cruise control, trailer connected/disconnected warning lights and sometimes the sway control intervenes randomly causing severe driving safetly issues. Every truck goes in at least twice in its life before being retired.
That 2018 was retired because it self destructed and earned a flat deck ride out of my life. Another 2018 just had its engine replaced as well.
Sorry, I can't even put together further details or even coherent paragraphs, I just hate these trucks that much. If you buy the truck solely for dry asphalt, unloaded, non truck driving, then have at it. If you want a truck that lasts longer, a used Lada is a better start.
I understand your indignation – if I had such a series of malfunctions, I would also have a grudge against the F‑150. Especially when technical problems occur one after another: VVT solenoids, chain jumps, wire knots backwards. On the one hand, the 5.0-liter is a powerful and on paper quite reliable engine, but the reality with the execution is sometimes very different.
Interestingly, the technical description says that the Coyote version for the F‑150 has a reduced compression ratio, a reinforced cooling system and an external oil cooler. On paper, this should give endurance, but practical realities show that even these improvements do not always save from dirty or cargo operation.
It would be interesting to hear more from those who have an F‑150 with a mileage of 200–300 thousand miles now without problems – whether they are lucky or simply have fewer technical flaws. Also, are there any owners here who have turned this body into a comfortable "home on wheels" and use it for travel, not work?
