In many of the more populated areas of the country, the EPA has mandated oxygenated gasoline & ethanol is in widespread use.
I think several of the Minnesota members of this board have used ethanol E10 for 8 yrs and it has been a requirement in the Chicago/Milwaukee region for approx. 5 yrs.
Ethanol use has been on the horizon for quite awhile, so the majority of fuel system components, over the last 10-15 yrs, for automotive, marine & small engines are formulated to withstand ethanol gasoline blends.
The recreational boaters commonly run ethanol blended gas here in WI. The fact that it readily absorbs small amounts of moisture/water is a benefit to most fuel systems. Any corrosion problems are related to water contamination in the gas and not caused by the ethanol.
