Originally Posted By: mk378
The sensors with one wire are simply a microphone. The ECU does all the signal processing and decisions.
Not true for all knock sensors, The BROADBAND RESONANT sensors on my Camaro(And all GM single wire knock sensors) Have mechanical amplification & filtering of the signal, Over a broad bandwidth in the knock range, provides high signal levels while allowing for typical sensor & engine variations. Broadband sensors are also less susceptible to engine noise and vibration (that would fool a flat response sensor) due to their ability to distinguish false signals with their high frequencies.
• FLAT RESPONSE sensors- Have a relatively flat response (4,000 Hertz). Universal in nature but requires a VERY specific configured ECM/Knock Module for each engine model.
I think it's more of a frequency than a voltage.
It's part of a feedback loop on many cars, so the PCM listens for "just enough" knock, if you can imagine such a thing.
BROADBAND RESONANT sensors are read in Scan Data as Voltage, I'm certain that's what people mean when they say that the sensor produces a readable DC voltage. In reality.....They're just seeing the converted DC Digital signal NOT the Analog A/C Sine Wave signature that the sensor actually produces.
Another interesting fact.....Broadband Resonant sensors "ride" on a DC Line Voltage (Results of resisted bias DC Voltage produced by the PCM & the internal resistance of the knock sensor itself), The bias voltage is usually 5vdc & is knocked down by the sensor resistance (1.5vdc-4.8vdc), If you back-probe the circuit with a scope on a 10vdc scale you will see the DC line voltage as the switch point for the AC sine wave pattern, If you set the scope to "AC Coupling".....The line voltage will be read as zero & you can see more detailed amplitude.
Flat Response sensors ride on a zero volt line (Sensor Ground Circuit), You can only see half the AC sine wave signature. It kinda difficult to see this signature & not think is a just a noisy circuit!
First pic....GM Broadband Resonant.
Second pic....Delphi Flat Response.
