Some code readers have the ability to clear DTCs. You can also disconnect the negative battery cable from the battery for about 15 minutes, reinstall it, and the code should be cleared.
Is your Cherokee OBD-I or OBD-II? I had a 1993 Explorer (OBD-I) and whenever the computer sensed that whatever was causing the code was back within acceptable range, the light went off.
However, on my 2000 Mountaineer, I accidentally left the mass airflow sensor unplugged after putting in a new air filter, which triggered a CEL. When I plugged it back in, the light didn't go off. It takes a few long drive cycles for the computer to find that the sensor is back in range.
