Originally Posted By: SR5
Originally Posted By: Shannow
Here's another one from the vault...albeit a 5W30 HDMO...
Interesting, and two very different 5W30s
SpectraSyn 6 with 12%VM, 8% Noack , KV100= 12.4 cSt and HTHS = 3.7 cP - HDEO
SpectraSyn 6 + SpectraSyn 8 with 3%VM, 6% Noack, KV100 = 10.5 cSt and HTHS = 3.2 cP - PCMO
That VII package is adding to both the KV100 and the HTHS viscosities in the HDEO.
Unless it's the few % extra Ester NP343 that is doing the heavy lifting (2% Vs 5%) or the DI (12% Vs 20%) in ( PCMO Vs HDEO)
I think I can see what's happening here and it's all being driven by the DI pack.
The HDDO 5W30 DI, at 19.9%, contains a shed load of Ashless Dispersant; far more than the PCMO DI at 12%. The extra Ashless really clobbers the CCS of the HDDO and as a result, there's no CCS head room to use PAO 8. As a consequence, the aggregate base oil KV100 drops and you need more VII to make your target KV100. As it happens, the target KV100 of the HDDO is way higher than for the PCMO because the HDDO has to make 3.5 min HTHS (it looks like they've over egged the pudding and unnecessarily gone to 3.7). As you might expect, these changes have increased the Noack of the HDDO relative to the PCMO.
To me, this comparison of 5W30 highlights just how silly modern oil formulation can be. In real-life terms, I would have absolutely no doubts that the 5W30 PCMO is way better (and cheaper!) than the 5W30 HDDO and that would hold true, even in diesel engines!
