How do I remove the wires from this connector?
JHZR2
Staff member
New Jersey
Cleanly... Want to protect the wires to reuse everything... Just need to swap wire position.
These are male plugs with two little "arms" coming off the plug to hold it in place.
Do I use a screwdriver to force the pins down then bend them back?
Thanks!
I'm thinking dremel tool, If i understand, you want the wires and pins completely free from the plastic connector. If you want to reuse the plastic connector, then i have no idea.
I'd love to reuse all of it... Hot and neutral were wired backwards... It worked but I'd like to make it right.
They should have some barbs that you have to depress so the terminals will clear the stops in the plug housing so you can pull the terminal out. Once you have the terminals out, push the barbsout so they will engage again.
Are miles puns always the same size??? Is there a different removal tool for each size???
