I developed a vibration and thought it was the tires which are like 5 years old, but let it go for month because it was at about 35MPH and went away at higher speeds. Then I read the universal joint squeak. So I crawl under and see a bad universal joint. I've replace them and the carrier bearing about 4 years ago. As you can see the seal went bad, but the others are fine. I think it must have popped off when greased during the install and dry rotted.
Anyway, I have a rear transmission seal leak. How is this dust cover removed? I'm kind of worried the bushing might need replacement due to the vibration.
