I saw a used oil analysis of 10w20 at the first open house. The oil held up well in a Mazda 2.5G. this engine is a cold weather fuel diluter. I have it in my Mazda now. I'm going to do a used oil analysis and also try the no vii 5w30 next.I know many vehicles can have this issue. How does your oil protect engines that contaminate the oil with excessive fuel?
I would prefer all members know the answer. Knowledge is power right?best to reach out directly to David at HPL.
Could their oil also help reduce fuel dilution by keeping rings cleaner and more tightly sealed?The only two ways to combat fuel dilution are more frequent oil changes or a higher starting viscosity.
HPL leverages some ubiquitous properties of oil (that they essentially “work-harden” from the heat exposure, and) thicken over time to try to offset this dilution, but as kschachn has posted several times, adding a low-viscosity fluid to a higher-viscosity fluid is a simple mixture calculation. There’s no magic bullet for this type of mixture.
I suppose after it’s cleaned everything up, a partial improvement may be possible, but the end-all “best” result will never be better than new without changing parts. Extremely thin piston rings with low-tension design are always going to let more fuel past the piston than a slightly thicker, higher tension design.Could their oil also help reduce fuel dilution by keeping rings cleaner and more tightly sealed?
From my amateur opinion, you’d need a gas-ported gapless top ring, a Napier gapless second ring, and a standard tension oil ring all with “proper to slightly-tight” end gaps to provide optimal sealing. No OEMs are going to use a setup like this because in uncontrolled conditions, all of these modifications generally have a shorter optimal life span than plain, low tension rings, from what I’ve seen. Maybe LSJr has some new tricks up his sleeve at Total Seal.
Speaking of that, why doesn’t LSJr have an account here?!?![]()
By being blended with higher quality base oils, viscosity index improvers, and a robust additive package. It takes a lot of fuel to put a dent in HPL's motor oils. That said, fuel affects the efficacy of ZDDP in any oil, so while HPL is one of the best motor oils currently available on the market that protects engines with fuel dilution issues, you should always do your best to avoid it.I know many vehicles can have this issue. How does your oil protect engines that contaminate the oil with excessive fuel?
Fuel dilution is caused by short tripping the vehicle, improper maintenance, abuse, and bad design. There is no motor oil that will fix any of that.Could their oil also help reduce fuel dilution by keeping rings cleaner and more tightly sealed?
Not surprising. It probably also has a higher HTHS than the OEM fill as well, providing more protection as well.In a CX9, HPL's 10W-20 had a higher KV100 at 5,000 miles than the OEM fill 5w30 at the same 5% fuel dilution.
And the opposite is true - which I have done by swapping in a quart of SAE30 from the Fumoto and drive a while longer …adding a low-viscosity fluid to a higher-viscosity fluid is a simple mixture calculation. There’s no magic bullet for this type of mixture.
I don't think it can because fuel dilution involves the mixing of a low and high viscosity liquid. Besides not all TGDI engines are big diluters. The best solution to dilution is to go up a grade, but it's best to know rather than assume if your engine has significant dilution. My own TDGI engine was at 1% over a 6500 mile oci. Not a big deal.I know many vehicles can have this issue. How does your oil protect engines that contaminate the oil with excessive fuel?
That is largely a matter of overall viscosity and higher HTHS. It is well known that (to a point) a higher viscosity tends to result in better ring sealing. There are a few dyno videos on youtube where they test this. As expected, the higher viscosity oil can, in some cases, make more HP, and result in lower emissions, despite the increased drag.Could their oil also help reduce fuel dilution by keeping rings cleaner and more tightly sealed?
And I assume they run on the higher side of their viscosity grade?Fuel dilution will certainly shorten your OCI depending on the severity of it. We've seen in some engines, such as the Honda 1.5L, where the fuel dilution was pretty significant, yet wear stayed low.
The higher end oils such as HPL can in theory buy you more time and with a robust dispersant/detergent package and high solvency base oils, you're going to keep the rings clean.
Not necessarily. Depends on the grade. Euro blends might. They use the most shear stable viscosity modifiers and even offer a grade that doesn't have them at all. Nice wide selection to choose from.And I assume they run on the higher side of their viscosity grade?
