Originally Posted By: HangFire
Originally Posted By: ZeeOSix
Purolator can run tests on a thousand filters in their labs if they want. If I was them, I'd be pulling filters off the assembly line and running them hard on their machines and cutting them all open for inspection. I'd think that kind of testing would be done all the time by filter manufacturers.
I told them about a media tear 3 years ago ... would think they would have looked into it then.
The word hasn't hit the street yet. So far the complaints have been limited to a few obsessed psychopaths on an oil forum.
From late 2011:
http://www.powerstroke.org/forum/94-98-7...er-failure.html
Very disappointed by the response. I should start such a business- if you catch a quality problem with our product, you've tampered with it, and there's no way to catch a problem (short of can burst) without tampering, so ha ha ha it's NOT OUR PROBLEM.
I have two Purolator's running right now, a Classic and a PureOne. I'm buying a better can cutter (previously I just cut crudely to drain better and take a peek). If they are OK I'll use the rest of each batch, since I bought a bunch at a time. If either have a problem I'll ping Purolator and start buying something else.
Referencing the other forum thread, this is exactly what I found, and posted (the thread with the vanishing pics), several days ago. The filter was a Pure One 20195. The first two pleats to the right of the seam were lose/not anchored to the top end cap and could be easily moved back and forth. Only the top was affected, the bottom seemed well anchored to the bottom end cap.
From late 2011:
