- Joined
- Nov 29, 2009
- Messages
- 9,521
Recently found a ripped ball joint boot on a recently installed ball joint. Not really sure if maybe road debris ripped it or what, but it's very irritating.
If it's a greasable joint , it will last a long time if it's greased every oil change. My guess it was damaged when the ball joint was installed.Recently found a ripped ball joint boot on a recently installed ball joint. Not really sure if maybe road debris ripped it or what, but it's very irritating.
Was it a Moog greasable joint?Recently found a ripped ball joint boot on a recently installed ball joint. Not really sure if maybe road debris ripped it or what, but it's very irritating.
Yeah. I suspect it got overgreased when installedWas it a Moog greasable joint?
Probably not, Moog has had these splitting boot problems for years. The problem is Moog uses a fixed ring molded in the rubber to affix the boot to the joint, it has no spit so it needs to be pressed on. I have seen multiple boots with cuts in the rubber right above where it goes on to the joint right out of the box at the parts store, the cut does not go all the way through but it is seriously weakened then when greased it splits.Yeah. I suspect it got overgreased when installed
So who makes ball joints/tie rod ends besides Moog? I don't understand why so many shops always insist on using themProbably not, Moog has had these splitting boot problems for years. The problem is Moog uses a fixed ring molded in the rubber to affix the boot to the joint, it has no spit so it needs to be pressed on. I have seen multiple boots with cuts in the rubber right above where it goes on to the joint right out of the box at the parts store, the cut does not go all the way through but it is seriously weakened then when greased it splits.
I use only Sankei 555 if I can find them for a particular vehicle, or on German heritage such as my BMW or my Tiguan I use Lemforder.So who makes ball joints/tie rod ends besides Moog? I don't understand why so many shops always insist on using them
Hope the current Dorman ones are OK, just ordered a set from RA. Sole sealed I could find.Probably not, Moog has had these splitting boot problems for years. The problem is Moog uses a fixed ring molded in the rubber to affix the boot to the joint, it has no spit so it needs to be pressed on. I have seen multiple boots with cuts in the rubber right above where it goes on to the joint right out of the box at the parts store, the cut does not go all the way through but it is seriously weakened then when greased it splits.
They advertise a little grease opening so they can't be over greased. I've had terrible luck with Moog boots either wayYeah. I suspect it got overgreased when installed
The Moog has a grease relief but the problem is the boot needs to be pressed on and that is where the problem is, they press it on but the cup damages the boot. I had a couple of conversations with them over this, the Euro style spiral rings are no problem. This is helpful...I see split boots all the time, esp the blue color lately which I think is Moog.
I'm still confused by greaseable with no specific, built-in release. Unlike a wheel bearing seal or u-joint seal, a boot typically swells with grease until something pops, pops off, or tears. So, purging old grease is not really possible.
In fact, the only time greaseable seems beneficial is once the boot has torn. Then, if you're diligent you can keep it lubed for longer than if there were no zerk (please, it's not zert).
The only ones that ever made sense were some Beck Arnleys with a "pinch nipple" that would let grease out but pinch itself shut absent internal pressure.
My split is like in the middle of the two jelly rolls for lack of a better term. Not on the very bottom. I do believe the relief is on the bottomThe Moog has a grease relief but the problem is the boot needs to be pressed on and that is where the problem is, they press it on but the cup damages the boot. I had a couple of conversations with them over this, the Euro style spiral rings are no problem. This is helpful...
https://www.moogparts.com/technical/bulletins/tech-tips/how-to-install-dust-boot-on-ball-joint.html
Trust me, this isn't sarcasm but can you explain? "Especially the greaseable ones"?I gave up on Moog years ago especially the greaseable ones.
That’s been my experience, they fail much faster than a good non-greaseable one such as a Sankei 555, even with proper greasing.Trust me, this isn't sarcasm but can you explain? "Especially the greaseable ones"?
Are there more failures in the one you can grease compared to the ones you can't?
I'm not sure that I understand. Am I missing something in your comment?
However, I must say that I do realize that MOOG isn't what they used to be!
When has Moog not been what they used to be? Since when the 50s?That’s been my experience, they fail much faster than a good non-greaseable one such as a Sankei 555, even with proper greasing.
