I've got a 95 Cadillac Fleetwood with the iron head LT1 (Caprice/Impala SS/Roadmaster) and while the cooling system performance is excellent (how about 195°F at 85mph with the A/C blasting in upper 90°F ambient temps?), I broke the radiator trying to replace the oil cooler lines. So I have the new radiator and I would like to flush the system. I have had good luck flushing with a garden hose, forward, reverse, engine on, engine off, pull the thermostat, etc, and I always use distilled water when I am done. I understand I may have block drains on either side (something other than the knock sensors I assume).
Anyway, I already insist on GC oil for my GM stuff (two small blocks, an L05 and this LT1, and a 3100 V6 - they all love GC, as did my LT1 Camaro when I had it), so I was wondering if I should be as picky for coolant. I just now found out that the all-makes stuff (specifically Supertech and Prestone) are very, very similar to Dexcool. Being a 95, my Fleetwood did not get Dexcool from GM, but it may have had Dexcool added somewhere down the line. Seems like I saw a reddish color come out. Some of that may have been rust, as I added RMI-25 a couple weeks ago, which by the way, I heard does not get along great with Dexcool. When I replaced the thermostat a couple weeks ago, I added a little 50/50 (all makes I believe) to top it off. Car has only 73k.
Seems like there are a lot of variables to juggle. I don't know for sure what's in there now. I have a gallon or two of Supertech all makes on hand, but my local Napa, which is very close by, seems to carry all 3 Zerex formulations, not including something proclaiming FLEET on it. Assuming I am sold on NOT running the all-makes stuff (any opinions?), how would I decide between regular Zerex green and G-05? What say everyone? It seems like the same folks that say "all makes" is great stuff also curse Dexcool, so if they are that similar, I can't trust the opinions of those people.
