Are they rated for inrush on florescent lighting? I have several lights in the basement, 48" tubes, IIRC I added it up once and it was 640W of lighting. I just replaced the switch with a standard 15A switch. It is a cheapo switch from Home Depot and I'm going to replace it, as it doesn't have a "solid" click to it.
Not quite so off-topic: I decided it was a bit chilly in the basement, so I figured I'd turn on a space heater to "high"--I usually use the low setting. I plugged it into an outlet, forgetting that it was a switched outlet. Turns out this outlet goes through this switch. When I went down a couple hours later it smelled really bad--like air out of an inner tube. Probably the heater, burning off whatever was on it (I've never used it on high). Going up out of the basement I flipped off the light (I had left it on) and did a double take when it felt warm... Flipping it revealed it was indeed warm--and now it wouldn't turn off.
Killed power to the basement, replaced the switch. Switch is rated for 3A/250V / 6A/125V, made by "Eagle" in the USA. I cracked it open; didn't find anything scorched, but it stinks like an inner tube, just not as bad as the basement now does.
I guess running a 1,500W heater through a switch rated for 6A isn't a great idea...
