At the i laws this weekend, and wife got zapped by a light switch. I checked it out. Metal plate, and it was hot. Killed the circuit, pulled out the switch. Wires twisted together, no wire nuts, grounds not tied to metal box, feed ground might not be tied to anything, neutral is being switched, bleh. I fixed the hot problem but not sure i want to volunteer to fix--not sure what CT requires. As it is I always have to look up which wire is hot.
My questions are, the wires should always be long enough to pull out for rework, and when did they come up with breakers with two poles on it? Not a 240 setup, but two toggles on one breaker.
