A common Hoover WindTunnel "Air Steerable" upright vacuum cleaner. UH72405 and similar models. A common problem on them is the brush motor will only run for 6 seconds. They have a button on the handle to turn the brush motor on and off. Press it, brush turns on for 6 seconds, then shuts off. The main motor for the vacuum works fine.
Any idea if I can hotwire the brush motor so it runs all the time? Or figure out which part of the circuit board to replace.
The original brush motor was shockingly rusty on the outside. Bought a new replacement motor to try. Same 6-second problem. An internet search will bring up many people asking for a fix and nobody has a fix.
The problem isn't something wrapped around the brush roller because it does it even with the brush roller belt disconnected. And it's not the lever/switch that keeps the brush motor off when the handle is fully upright. One plug on the circuit board is for the brush motor power. The other is for that brush motor "upright" switch/lever.
