Got it filled up this weekend and was seemingly working fine. Saw some water on the bottom but with filling and my 8 year old playing in it, figured it was just spillage. However, notice couple of days later, bottom was a little wet. Pulled the cover off and there is a small pin-hole leak coming from one of the jets going into the hot tub. About a drip every 6 secs or so, no problem. They usually fix themselves and the hot tub had been emptied for about two years. Anyway, fired up the jet pumps and there was a stream of running down the bottom of the hot tub. Didn't take the side cover off, got to move the deck, PITA. Anyway, this is obviously a pressure leak. Before turning the jet pump on, the bottom of the floor was bone dry. After firing up the jet pump, it was all wet with a good size flow. Not like it drained the hot tub, but you could tell. I'm thinking this is NOT a pump seal leak, correct? It only leaks when the pump is on. Would the pressure from the pump force the water out of the actual water pump? Could this be a simple loose hose or something minor like that?
