I don't think we are thinking the same part. This attaches to bottom of hood.It can also increase air flow through the radiator by reducing the air pressure under the hood. My old Merkur had a small flap hanging below a front crossmember. It was only about 4 inches wide and stretched across the entire width of the car. They were also prone to damage from road debris.
If that flap was not in place, the turbo would overheat due to reduced air flow.
This engine only takes 6L or coolant total.It was my understanding that it is part of controlling engine temperature, to optimize efficiency for emissions and fuel economy. The engine bay on my E350 not only has the rubber gasket on the leading edge on the inside of the hood, but also has rubber gasket seals on the sides and rear of the engine bay. Then of course it is sealed underneath with plastic panels.
I recall reading somewhere that by sealing off the engine bay, so airflow is mostly controlled and limited, to that which flows through the radiator, engine operating temperature can be more precisely controlled. By controlling the engine operating temperature, it can operate much more efficiently, reducing emissions and improving fuel economy.
At the base of windshield or at the front of the hood? The cabin air intake is behind the rear hood seal at the base of the windshield and that one I would probably replace as it helps keep engine odors out of the car. The front one, could be raising or lowering underhood temps or just helping aero dynamics a tiny bit? Probably doesn't matter much with most cars.I don't think we are thinking the same part. This attaches to bottom of hood.
At the base of windshield or at the front of the hood? The cabin air intake is behind the rear hood seal at the base of the windshield and that one I would probably replace as it helps keep engine odors out of the car. The front one, could be raising or lowering under hood temps or just helping aero dynamics a tiny bit? Probably doesn't matter much with most cars.
How does coolant capacity relate to controlling airflow in the engine compartment, and controlling engine temperature? What size engine?This engine only takes 6L or coolant total.
Of course it's not the same part, that was an example. It may serve a similar purpose though, so it should be repaired.I don't think we are thinking the same part. This attaches to bottom of hood.
