I have a 2007 Honda Accord with a 2.4 and a A/T.. It has 90,000 on it....Yes I drive alot.... I have noticed over the past month or so since I installed Michelin Primacy tires and gear type transmission sound. The reason that I mentioned the tires is because these tires are sooo quit over the OEM Michelins that you hear everthing now not road noise like before. The slight whine is between 40 and 45 and around 50 to 60. It is not loud and if you have the radio on you probably wont hear it. The whine seem to happen the most when you are at these speeds and you have a very slight acceleration... I mean a very light load. It sounds like a gear type whine and not a wheel bearing. I have eleiminated the engine because I have drove at 60 mph and put it in nueteral and turned the engine off and you can hear it very slightly as it slows don through those speeds mentioned above... I have read other posts on other site that this is common on the Honda and even the acura... The fluid is fresh and I change it. Any Honda owners out there or transmission experts out there.... That can give me any advice on this as if it something to worry about or not....other that the whine the transmission work with no problems at all....fluid has always been nice and pink with just a little crud on the drain bolt when I change the fluid. I want to keep the car for a while but if a transmission issue may be cropping up I may not.....Thanks
