Originally Posted By: Cujet
To be specific about Honda's GX390 oil recommendations, they claim 10w30 for general use. Straight 30 for temps over 10C (50f) And for LPG GX390's they specifically prohibit multi grade oils and simply require straight 30.
As I continue to say, post hurricane generator operation here in South Florida really "taxed" many generators. And while few of the failures were Honda engines, there were some. I had 2 Honda water pump (for de-watering my 2 acre lot) engines fail on Pennzoil Multigrade oil. Honda was good enough to warranty them. The second one, they really complained about.
I'm going to go ahead and use delo 400 15w40 in everything. Rarely does it get below 40 degrees, so I'm assuming the oil will be fine. If you can run a 30 weight then you can run a 15w40 I'm assuming.
I now use Mobil 1, 5W-40 in everything. It's a robust oil, with a fantastic additive package, and it's performance under very high temperature conditions is superb. (HTHS 3.8)
Note: My Kawasaki powered Snapper mower regularly had oil temperatures North of 260 degrees F ! And, that's normal.
Many of the generator failures (local to me) were caused by people heating water (4500W) for 3 to 4 hours. This was often at the absolute limit of the typical homeowner generator. Parked next to the garage, the stagnant air would simply recirculate, the oil temp would climb, and the connecting rod large end would seize on the cranshaft. Leading to catastrophic failure. Honda engines are not immune to abuse, as I found out.
