Honda GX270 Engine
CA
I recently purchased a pressure washer that is equipped with a Honda GX270 engine. The manual is silent on the recommended oil type, but the package included a 32 oz pouch of 10w30.
Would a small engine benefit from a high-zinc oil such as Valvoline VR1?
I don't really think so. The high ZDDP oils are for the camshaft, and the small engines have such light spring pressures that it is not necessary. I have been running my rider with a Tecumseh engine for nearly 50 years with just any cheap 30 oil, and the last 4 or 5 years 10w30 or whatever, and it still runs fine.
The GX270 manual from honda is fairly specific as in as long as you use oil that is SJ or better
If it’s anything like my 160. I use what ever 5 or 10W30. Currently Mobil 1 High Mileage 5w30 and left over AMSOIL Signature Series 5w30. Before that T5 10W30. I did use Amsoil Small engine for 4 years. 13 years old now and runs great.
My mower has run 17 years on 10w30(ish), about 30hr/yr.
Started off with 10w30. Then collected all the half-quarts and poured them together into a Mobil 1 5 qt jug. It's a mix of conventional 10w30 and Mobil 1 10w30. Then, whenever I do an oil change on the cars/motorcycles (0W-20, 5w30, 5W-20, 10W-40, etc), I turn the empty bottles over and drain all the drips into a container. This drip oil goes in the mower first and I top it up with the 10w30 brew. Works great. Mower does not use any oil and it drains clean when I do an oil change every year or two. Also, I don't have a bunch of half-empty oil bottles laying around!
I believe there is no catalytic convertor, unless they changed, so you are free to use a HDEO. I use Rotella T5 10W30. It’s well proven that Bitoggers pay way too attention to small engine oil than it is worth. ;)
