50 k miles, 5w20 syn, dumped at 50% OLM (due to Fuel Dilution)
OEM dunlops replaced with Michelins, countless wipers, brake flushed a few times at dealer, transmission drain and filled 3x.
Overall: I like the trunk space, I can put a large cooler behind the back seat. Very bumpy ride, feels like I am riding a moped. Alignment is faulty and front tires wear out on the outside even after repeated trips to dealer to align wheels.
mpg: I get no where near the window sticker, I stopped keeping track. it is less than 30 mpg for sure.
Issues:
1. A/C dryer tower leaked from FACTORY, slow leak. dealer refilled gas and put in dye and sent me away. DID NOT FIX issue.
2. Vehicle leaked water from day one, in fact vehicle has a layer of ice on the inside of the windshield a day after I bought it.
3. Valve train makes funny noise sometimes, VERY noisy, sometimes and power is diminished.
4. HVAC heat to feet is faulty and does not work properly.
5. LARGE blind spot due to the front window and pillar design. You have to be extra cautious and not hit a pedestrian.
6. Alignment issues - fit eats the outside of the front tires.
Conclusion:
I can't in good conscious recommend a Honda Fit, mainly due to the dealerships and Honda attitude towards owner and their unwillingness to fix problems that they know many car suffer from.
I read about Honda Fit loose spark plug issue, now I need to check my spark plugs.
I can promise that this will be my 7th and final new Honda. Maybe a used s2000 someday.
I thought dealing with chevy over warranty issues was bad, dealing with Honda take bad CS to a new level.
Issues:
Conclusion:
