An (84 year old) employee just traded his old Mitsubishi Montero for a 2005 Honda CRV.
We drained the 20W-50 from the engine and are trying 5W-30 for now.
The transmission barely shifted, so we are changing the 80W-90 GL-5 to a 5W-30 CI-4 (closest thing in Bolivia to a MTF). We've already saved many GM and Honda transmissions with this solution.
The Rear Differential sounds terrible, and has 80W-90 GL-5 in it instead of Dual Pump Fluid (which is not available here). For the moment, as a rinse, we are putting in Dexron, as it has got to be better than GL-5. I know in the early days of CRV's it was an acceptable temporary substitute, but understand that as of 2005 or so Honda added cogs or something that act like a limited slip.
I'm looking for suggestions as to what to replace the Dual Pump Fluid with. Please don't bother to say order from the dealer or by internet, as the dealer does not carry it (they put 15W-40 in the engines and won't listen to reason), and it is not allowed into the country without prior registration, which is a 4 month $200+ process, and there are really very few Hondas in the market.
Dexron?
Dexron with LSD?
Universal Synthetic ATF that meets the Honda transmission spec?
Dexron?
Dexron with LSD?
