So at 79K my maintenance minder indicated it is time for a transmission fluid change. I already had done 1X drain and fills at 23K and 54K, so I decided to just do a 1X now and another drain and fill at the next 2 oil changes rather than all in 1 day. When at the dealer buying fluid, I asked what they do when the maintenance minder goes off. I asked if they do the Honda recommended procedure of 3X drain and fills. He said, "Honda recommends 3X drain and fills but we only do 1X drain and fills. That's good enough." I was shocked. I'm sure they do this because of price, since it's $125 for 1x so I bet most consumers won't pay $375 for a transmission fluid change. Still, it bugs me that most people won't do drain and fills regularly, and when the maintenance minder goes off, it's because the calculator has determined the transmission fluid is toast. The engineers want it all changed out, but the dealers won't comply. For instance, my Accord holds 7.6 quarts and a change only changes 3 which is only about 40%. I wouldn't be surprised if this corner cutting contributes to some Honda transmission failures.
