I'm worried about the oil temp at a constant 6100 rpm... if the oil temp can be controlled to 250°F or under, the 0w-20 will do, but above that the temperature in the big end bearings might exceed 150°C, and the oil viscosity will drop below the HTHS viscosiy of the oil.
So get an oil with higher HTHS in that case.
If the engine during hypermiling operation stays below 2000RPM, there might even be a benefit to going to a slightly thicker oil. While you will get more viscous drag in the bearings, you could get reduced boundary/mixed/elastohydrodynamic lubrication in the piston/liner assembly, and a higher percentage of full hydrodynamic lubrication resulting in an efficiency gain.
The really thin oils shine most in the mid of the rpm range, not at the low end.
