Finishing up a timing belt job on my Saturn. Reading the instructions in the Aisin kit which also covers Hondas and Acuras. For the Vue it says to tighten the bolt to 181 ft. lbs., same as for the Acuras. But for the Hondas, it says 47 ft. lbs. plus 60 degrees. Why the difference when the basic engines are identical (I thought)? And the latter would be simpler I think. 47 ft. lbs with a torque wrench, then 60 degrees with an impact wrench would be easier than taking it all the way to 181 ft. lbs. with the torque wrench when the vehicle is on jack stands and you can't get much leverage lying on your back under the car.
