I have a little hotel sized fridge that works fine, however the door seal is bad and the hinges are coming off. I was thinking of taking it down to my shop, and make a new door out of plywood and foam insulation, and, inside run several lengths of 1/2" copper pipe with appropriate water traps at the bottom. Then I could run all my hot, wet compressed air though it and hopefully get dry air on the other side?
I know that's basically how industrial refrigerated air driers work, but would a small fridge like that be able to keep up with all that hot air? Maybe it would work better if I used something like an automotive heater core instead of copper pipe? Or maybe I could just go with a full sized fridge - there's no shortage of old free ones on craigslist.
Anybody ever try that before?
