So I was doing some easy work at the GF's parents house.
Did some powerwashing. Installed a new Garbage Disposal.
Well they wanted me to replace the second bathroom's faucet.
They rarely use this bathroom (luckily). The cold water wasn't working and it was dripping fast.
Started work on it.. First problem The cold water shut off.. isnt shutting off. Appears it was damaged from heavy mineral deposits.
I turn the whole house water off.. Crank the cold water shutoff in the bathroom back and forth about 5x and it shut off to a slow drip... Not great but ok to continue with the job.
Next issue the retaining nut for the hot water tap under the sink fixture has massive buildup on the threads around it.
Its makes it like UBER locktite. Tried picking the threads for 20min.. Then forcing it off.. no dice.
I noticed the sink is just resting on the cabinet.. so I decide to remove the whole sink and saw off the nut with a hacksaw...
2 min later I gave up and told them "you need a professional.
See Pics below for what I found.
Note House is on slab construction with pipes in walls.
The cold water tap that wasn't working.. maybe it was full of mineral debris eh?
The hot water side that actually worked... but it had a weak flow... wonder why
When I decided to remove the sink from the cabinet to saw off the faucet The drain pipe fell limply to the cabinet floor upon removal... UH-OHH
Yep that's supposed to be attached somewhere inside the wall.. it was just lying there with the water running into the wall. Hopefully it was still holding on by a thread or something so its not all moldy in there.
The In-Wall pic
The In-Wall pic
