What?I run all my machine tools at my house on 240. I even run my desktop on 240v. My electric bill is nothing... The only way to go
He must have changed the outlets in his house to 240 instead of 120. Electric motors that can do 240 or 120 actually last longer at 240. Many power supplies have switches where you can run it at 240/120, all you need to do is flip the switch on the power supply. Relatively simple to do a 240 volt outlet, all you need is a double pole 20 amp breaker. Instead of a hot, neutral and ground wire, you just have two hot wires and a ground wire and it's the same size outlet, just a different looking plug. I did that for a treadmill, most gyms dump their old ones after a few years and many of them are 240 and they're cheaper than the 120 volt treadmills. You could pick up a 7k treadmill for about 1k or less and that is way sturdier than any home brand 120 volt treadmill.What?
Good point! I would run a dedicated circuit, and if doing that anyway, might as well make it 240.Another thing to consider is that if you are charging at 120V, the outlet you are using is probably daisy-chained through half a dozen other ones with backstab connections. Probably not the best situation for voltage drop.
Yes, apparently Edison used to play up the dangers of AC, and suggested that criminals be "Westinghoused" to death with AC.It's the way it's always been. If you think that's bad Japan has different standards on the same island. There may also have been an old school perception that 120 was tolerably non-lethal if you took it directly.
Edison's light bulb was the killer app for his 120V DC dynamo "Edison Plant". DC only covers short distances (~2 miles) so Edison wanted a licensed Edison power plant in every town.
Westinghouse waltzed in with his distance-capable AC power and electrified Buffalo via Niagra Falls, 20 miles away. He made his average voltage ~115 so it would work with Edison's light bulbs and basically "stole" them. The two hated each others guts!
These electrical standards bled over into television-- NTSC ran (nearly) 30 frames per second while the Euro standard was 25, as that was doable with the analog circuitry that ran off the mains frequencies.
I put a subpanel in my garage so I have both 240V and 120V dedicated circuits. Wasn't that much more expensive to do that.Good point! I would run a dedicated circuit, and if doing that anyway, might as well make it 240.
Same nomex wiring?He must have changed the outlets in his house to 240 instead of 120. Electric motors that can do 240 or 120 actually last longer at 240. Many power supplies have switches where you can run it at 240/120, all you need to do is flip the switch on the power supply. Relatively simple to do a 240 volt outlet, all you need is a double pole 20 amp breaker. Instead of a hot, neutral and ground wire, you just have two hot wires and a ground wire and it's the same size outlet, just a different looking plug. I did that for a treadmill, most gyms dump their old ones after a few years and many of them are 240 and they're cheaper than the 120 volt treadmills. You could pick up a 7k treadmill for about 1k or less and that is way sturdier than any home brand 120 volt treadmill.
Yes, you can use the same Romex wiring. You basically have two sine waves at 120 volts and when you add two sine waves together you double the voltage. With a hot and a neutral, you just get the 120. The Romex isn't carrying any extra voltage, just two hot wires instead of one hot wire. In this case, it would be a 20 amp double pole breaker.Same nomex wiring?
Why haven't houses been wired for 240v instead of the common 120v?
okay so then it would be a matter of updating the individual breakers, every outlet and fixtures (light bulbs, ceiling fans, hand held appliances, etc)Yes, you can use the same Romex wiring. You basically have two sine waves at 120 volts and when you add two sine waves together you double the voltage. With a hot and a neutral, you just get the 120. The Romex isn't carrying any extra voltage, just two hot wires instead of one hot wire. In this case, it would be a 20 amp double pole breaker.
As for why 120 instead of 240, houses are wired for 240 at the panel. There's 3 wires coming in, two hot wires and one ground. At the panel, there's 240, the two hot wires on each pole. You can either tap 120 or 240 depending on what you need.
No it’s the same amount of power, you don’t get anything for free. But the current is cut in half so you can use a smaller wire gauge which is less expensive. But if the wire is already run you’re not going to recoup anything in that regard.okay so then it would be a matter of updating the individual breakers, every outlet and fixtures (light bulbs, ceiling fans, hand held appliances, etc)
How does this impact power usage? Less power with the 240V system?
OKay. Zee09 implied that because he went 240V that is electric bill was next to nothing so I was confused. BTH I don't remember much about electricity.No it’s the same amount of power, you don’t get anything for free. But the current is cut in half so you can use a smaller wire gauge which is less expensive. But if the wire is already run you’re not going to recoup anything in that regard.
Yes and he was informed that his implication was faulty. The electric meter measures power (watts) so its independent of the voltage being used.OKay. Zee09 implied that because he went 240V that is electric bill was next to nothing so I was confused. BTH I don't remember much about electricity.
I think it's politics, national pride etc.Honestly I don’t know the truth on 50 vs 60Hz, as the things I speak of won’t have a huge difference.
I'm not sure they hated each other's guts. Tesla worked for Edison for awhile. Tesla invented the AC that we all use today while Edison gets all the credit. Tesla was a brilliant idea guy but couldn't put thoughts into action. Edison was good at implementing ideas to the real world. Tesla would have been one of the richest men in the world if Westinghouse had not screwed him. He was originally supposed to get a cut of every house that was wired. Edisons idea would require a power plant every few blocks. I'm a few miles from Edison's winter home in Ft Myers. It's a very interesting place to visit. There are some original phonographs there they they demo for you and some of them sound good by today's standards.It's the way it's always been. If you think that's bad Japan has different standards on the same island. There may also have been an old school perception that 120 was tolerably non-lethal if you took it directly.
Motors tend to last longer at the higher voltage than the lower voltage. But a kilowatt is a kilowatt no matter what the voltage is. I would actually have to see the specs of the equipment to say whether or not it's using less power and the amount you're really saving. You do have a limited number of breaker slots and it's not that easy finding everything to run at 240.OKay. Zee09 implied that because he went 240V that is electric bill was next to nothing so I was confused. BTH I don't remember much about electricity.
Didn’t Tesla die in a hotel very poor or something? If he did become the richest man in the world, the outcome is the same.I'm not sure they hated each other's guts. Tesla worked for Edison for awhile. Tesla invented the AC that we all use today while Edison gets all the credit. Tesla was a brilliant idea guy but couldn't put thoughts into action. Edison was good at implementing ideas to the real world. Tesla would have been one of the richest men in the world if Westinghouse had not screwed him. He was originally supposed to get a cut of every house that was wired. Edisons idea would require a power plant every few blocks. I'm a few miles from Edison's winter home in Ft Myers. It's a very interesting place to visit. There are some original phonographs there they they demo for you and some of them sound good by today's standards.
He said he pays nothing (someone else is paying), not that electricity use is zero.Yes and he was informed that his implication was faulty. The electric meter measures power (watts) so its independent of the voltage being used.
He did? Guess I missed that part, I looked back and don't see that part. What I read was:He said he pays nothing (someone else is paying), not that electricity use is zero.
So I took that to mean that his use of a higher voltage reduced his power to "nothing."I run all my machine tools at my house on 240. I even run my desktop on 240v. My electric bill is nothing... The only way to go
I guess I misread then.... Maybe he blew his machine tools so it won't work.He did? Guess I missed that part, I looked back and don't see that part. What I read was:
I presumed that Zee09 was joking when he posted that he ran everything on 240 V.I guess I misread then.... Maybe he blew his machine tools so it won't work.
