Originally Posted By: benjamming
Originally Posted By: Brett Miller
My system has a 5" thick media filter. I usually get about 10 months before the system indicates changing. I have heard of a lot of problems due to the 3M filters since they are very restrictive. Iced coils, burned out blower motors, and cracked heat exchangers.
How does the system indicate changing - minihelic gauge?
How does it crack heat exchangers?
I have a Carrier Infinity system which measures the pressure drop across the filter. When the restriction reaches a certain point, it will indicate to change the filter. A cracked heat exchanger results from the poor airflow created by the 3M filter which causes the heat exchanger to get hotter than normal.
