Our 1982 BMW 320i has a recent habit of idling at about 1400 rpm when warm. It should be 850 +/- 50 rpm.
I'm not exactly sure where to start diagnosing this. I don't believe there are any vacuum leaks, I'm getting 14" of steady vacuum at idle and the engine is operating properly. Valves are properly adjusted, timing is good, and the stuff that would immediately come to mind (such as the idle speed screw) has never been messed with, so I don't know why it would change.
Any ideas from anyone here as to where to start looking? On a hunch I did play around with the cold fuel injector and the auxiliary air valve but it would appear neither are the culprit - pinching the aux. air valve line doesn't change idle speed, nor does unplugging the injector.
Hoping someone on here has some experience with these old M10 mechanical injection units.
