Originally Posted By: bobbydavro
Originally Posted By: Joe90_guy
Okay, let's restrict ourselves to solids and bypass the 'designed-to-confuse' slate of liquid dilutions that's offered up.
Sv50? Oh dear. Where do I start? God awful to dissolve. Stupidly low SSI (why???). Good on basic polymeric efficiency. Hopeless on HTHS.
Sv250? A lower SSI, sheared down version of Sv260. Makes no sense at all as a VII.
Sv300? High SSI version for The Rebel Colonies. Died peacefully in its sleep about a decade ago.
What did I miss?
Don't fret yourself about going off topic. This thread has meandered all over the place already and is all the better for it.
To name two which are more recent and in the public domain
SV200 - very shear stable and a big HTHS boost vs Kv100
SV600 - Fuel economy - but does give a high VI in final oils (>200)
SV150 DVM too
I took me a while to remember what Sv200 was. It was really, really old when I first started working in crankcase so it must be positively ancient now.
Thankfully I found this patent which contained all the numbers I needed to refresh my fast fading memory (BTW is this your mob?)
http://www.google.com/patents/EP2504416A1?cl=en
Sv200 is the ultimate sheared down version of Shellvis rubber with an SSI of close to zero. HTHS performance is better than Sv 260 and Sv 250 but only because there's so little for the HTHS machine to shear down (even then, it's HTHS performance isn't fantastic). But you pay a hefty price for this because the polymeric efficiency of the smaller VI chains drops like a brick. I'll wager that if you put up a 22 SSI OCP against a zero SSI Sv 200 in a HTHS limited xW30, factor in the raw polymer loadings and costs, the OCP would do surprisingly well.
Sv600 doesn't ring any bells. I know there's data on it in this patent but whilst I can read the words, I can't yet read the tabulated data. I'll keep trying.
https://www.google.com/patents/WO2015097152A1
It does occur to me that Sv600 might just be Sv300 reincarnated? It would fit the profile you describe. If your objective was purely to create an oil with a ridiculously high Viscosity Index and then attributing great fuel economy to the oil, then using an extremely high SSI Sv polymer would I concede make sense. But would you not be a tad concerned about the ethics of doing something like this? You're basically pimping a oil that falls to bits???
