The vehicle in question is a 2023 Subaru Outback 2.4L Turbo with the TR690 CVT, but I'm interested in having a primarily technical discussion about fluid so this could apply to other vehicles which specify a "high torque" and/or low viscosity CVT fluid.
OE would be the "safe" choice, but Subaru likes to sell their fluid in 5 gallon buckets and they have 4 types. Yet there are aftermarket fluids that claim compatibility with multiple specs, with Amsoil, Valvoline and LubeGard claiming the widest range of matches.
So first, what makes a CVT fluid suitable for high torque applications? Initial theories:
The second piece of the puzzle is viscosity. While it is relatively easy to find aftermarket solutions for LV and ULV applications in step shift applications, CVT fluid seems to be a one size fits all thing in North America. Interestingly, there are several dedicated LV CVT fluids in the Australian market.
I'm interested in hearing thoughts and theories, as well as experiences with aftermarket fluids in high torque and/or low viscosity applications.
- It is simply branding / marketing... but some fluids specifically state that they are not for use in high torque applications so that leads me to believe there is a real design difference
- Better quality base oils to resist oxidation and shear in high heat / high load applications
- Higher dose of friction modifiers and additives, or possibly a completely different additive chemistry
- How big of a deal is it to use a somewhat higher viscosity fluid (such as Amsoil, with a cSt of about 7.1@100°C where the OE fluid may be closer to 5.5 cSt)?
- The same applies in reverse, but seems like less of a concern considering that UOAs indicate that the OE fluids often shear to this level during normal use, and these fluids should be more shear stable.
- How can aftermarket companies claim such broad matches? Is it just that OE manufacturers only validate one fluid type and recommend that to be on the safe side?
- Are CVTs as finicky as people suggest on fluids? Fear Uncertainity and Doubt are quite common, but rarely if ever does anyone post any definitive evidence to back up their claims that Amsoil, Valvoline, etc harmed a transmission.
- Which would you rather have? Dirty, oxidized and sheared OE fluid or at least some fresh aftermarket fluid that is not an exact match in viscosity or additve chemistry?
