Hi All,
I am restoring an old Hoover vacuum cleaner. One end of the motor shaft rides in a K-65 caged needle bearing. I have replaced this bearing with an identical new one (link below) but would like to know what would be the best LIFETIME grease for this bearing and application--I don't want to have to take this thing apart again.
When I re-assembled the motor with the new bearing for the first time, I used some unknown dark grey grease with the consistency of Miracle Whip. This grease sample was given to me by a machinist--he pumps it out of a grease tube gun into the grease points of lathes and mills etc--but I don't know how well it will last in this potentially higher speed and higher temperature application. Is it likely that the volatile compounds will vaporize out of the grease, leaving behind a gummy residue and a loud bearing?
https://www.amazon.com/Koyo-J-65-Bearing...ds=j-65+bearing
Thanks.
